Got an easy one for someone to solve. I've created a 3D plot, but the plot doesn't show all of the data.
I'm reading data from a set of .txt files and trying to visualize the results via the 3D plot. Each txt file contains a set of 401 data pairs (y location, measurement). A scalar (x location) is assigned to each file set, then added to an array containing data from previously read files. The resulting array is parsed, rearranged, etc. before going to the 3D Surface Plot control. Looks goofy because this .vi was originally used to combine data from multiple .txt files into a single file.
As you can see from the screen shot, the 3D plot only shows data from 400 to 445 (input data goes to 800). I checked the plot input arrays/matrices to ensure all of the data was read from the .txt files (it's all in there). What am I missing?
The .vi is attached along with a sample .txt file.
