02-16-2009 09:18 AM
I am attempting to display 3 waveforms on a chart using live data samples. The waveforms draw ok in terms of the samples being in sync with each other, however parts of the waveforms are missing. (see attached screen shot, there is only one waveform shown for clarity)
I am using the sweep mode and sections between points are missing, however when I set it to either of the other 2 modes the missing lines appear and the chart is drawn normally. I really need to use the sweep mode for the visual aspect so really need to get this sorted.
I am measuring the surface of a round shaft and take a sample every degree, so obviously the chart is 360 samples long and then starts from the beginning at 0 degrees. This program has been running ok for about 6 months and then the computer died, so just sorting it on a new machine and this problem popped up...
Thanks in advance!
Darren.
Solved! Go to Solution.
02-16-2009 09:25 AM
Wortel wrote:Hi,
... This program has been running ok for about 6 months and then the computer died, so just sorting it on a new machine and this problem popped up...
Thanks in advance!
Darren.
Make sure you have the latest a greatest driver for the vidoe interface. If that odes not fix try reducing the graphicl accelerator settings.
Ben
02-24-2009 02:22 AM
It turns out that the problem was caused because I had moved the waveform chart to the back of the view, as soon as I changed it to 'Move to Front' the problem went away.
Cheers,
Darren.
