NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
andrej
Accepted Solution
Minimizing the application (all open windows)
I have an application that has more windows (W1, W2, ..., Wn) where W1 calls W2, W2 calls W3 and so on (when Wn is open Wn-1 can not be accessed). I want to minimize all windows when user minimizes Wn. How can I do this? I could use references to all previous windows and minimize them using invoke node, but I don't like this method. Is there any other way to do this? Maybe on the application level?
Thanks!
Active Participant zou
Active Participant
zou
Re: Minimizing the application (all open windows)
If you are using MS Windows, you can use Windows API to do this.
Just find the "labview" window, and minimize it.  All LabVIEW windows will be minimized.
Member
andrej
How can I find "labview" window or all labview windows. I have tried minimizing using the VI name, but it minimizes only the top window, other labview windows are not minimized.
Trusted Enthusiast
TiTou
Hi
I have an app that has more than one front panel open at the same time, it does create some issues somtimes, for instance when you "alt-tab" through the open windows in Windows.
To minimize all my Vi's front panel at the same time, there is a button on the main VI, when the user hits it I use this VI (attached) to minimize all the opened FP.
I'm sorry it's not documented, but basically you have to place it in the main VI of your app and pass in the ref of the main VI, when run, it take take the ref of all the VIs in memory that have their front panel open, minized all of them and old their ref in  the array that's in a shift register and then it wait for the main VI to be opened by the user and then re-displays all other FP that were opened.
Hope this helps
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Member
andrej
Thank you. Actually I did similar VI, but I was hoping that there is some other solution where I don't need to pass a parent VI reference to a subVI.
Active Participant
pcardinale
What's wrong with doing it per VI?
Trusted Enthusiast
TiTou
Well I don't know how Andrej's application is architectured but is he has independant processes that have different FP and if he want to minimizse all the app's FP when one of them is minimized he can't use your VI.
Maybe your VI would be fine... I just posted the VI I'm using for my project in case it can help :smileywink:
Cervantes
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
