Micro-Nuggets !!! ~~~~ Post 'em if you got 'em
@BowenM wrote:
I found the need to find if an application was running on 32 or 64-bit Windows.  Forum searches only brought me to a LAVA page and a rolfk attachment that returned
"The page you are trying to access is not available for your account."
Strange! When I click on the attachment in the LAVA post I get the VI downloaded.
Rolf Kalbermatter
My Blog
Message 321 of 361
(3,337 Views)
@GregSands wrote:
Haven't seen this micro-nugget before - if you hold the Delete key down, then objects are immediately deleted as you click on them.  Not hugely useful, but who knew it?  Works on the BD and FP since at least LV2012 (earliest I can check at the moment).
I have never really know this till now. Additionally by clicking and selecting multiple items deletes them all!. Thanks for the nugget.
Message 322 of 361
(3,315 Views)
Log out of LAVA and try it again. I don't have an account at all.
Message 323 of 361
(3,233 Views)
You can log out of LAVA?  LAVA like many forums require you to login to download off of the site.  The error message "For your account" I likely because if you aren't logged in you are on a Guest account.
Message 324 of 361
(3,211 Views)
Sorry Hooovahh, Rolf
I get this from here
https://lavag.org/applications/core/interface/file/attachment.php?id=4191
until I actually log in to get this download
which isn't much different than the Hidden Gem
which also depends on the LabVIEW Context as explained here
"Should be" isn't "Is" -Jay
Message 325 of 361
(3,197 Views)
If you press and hold the Step Out button while single stepping the nested structures, it shows the list of the things you can actually step out from:
Message 326 of 361
(3,186 Views)
I never said it was, and as far as chronology goes, the LAVA post predates the Gem quite a bit. Smiley Happy
What do you mean by this? This conditional compile setting is not depending on the VI being part of a project like a few others. It will be always set to the value for which the VI is currently compiled, which is also deterministic outside of a project.
Rolf Kalbermatter
My Blog
Message 327 of 361
(3,139 Views)
We should probably branch this but...  Assume that a developer had a 64 bit processor and a 64 bit OS and LabVIEW 201x x32 and x64 installed side by side.
(I don't have a system like that too test)
From my understanding after reading the help.
The vis attached to my reply will return the bitness of the LabVIEW IDE and not the bitness of the OS or CPU.
The desired return is the OS bitness.  WHICH is supposed to be agnostic of the hardware or the context of the program it enables to run
Message 328 of 361
(3,122 Views)
The logic, in my VI at least, is as follows:
If the current executable is 64 bit, the OS MUST be 64 bit (you can't run a 64 exe on a 32 bit system).
Otherwise determine if the current process is running as WOW64 process, if so it is a 32 bit process running in the 32 bit compatibility layer of 64 bit Windows. Otherwise it must be a 32 bit OS.
Rolf Kalbermatter
My Blog
Message 329 of 361
(3,115 Views)
 Exactly.
The context in which the process runs and NOT the OS bitness.
(Don't Make me go full circle and suggest a hack like looking to see if a folder exists)
Message 330 of 361
(3,106 Views)
