I have an application with two VIs. The application is attached.
In the first VI there is a Button that when you press it then the second VI is open and the first VI closes. The same happens in the second VI. The proble is that when the before the seconf VI open a message :Resetting VI: is appears. This message is diappears instantly. How we can get rid of this annoyed message? We use LabVIEW 8.6 under SuSe Linux 10.3 and others distors.
Yhe same appliaction works fine in the LabVIEW 8.6 for Windows.
Please help us ASAP.
Ελευθερία σημαίνει ότι μαθαίνεις να έχεις απαιτήσεις μόνο από τον εαυτό σου, όχι από τη ζωή ή τους άλλους
