Merging two 2-D arrays?
I have a  question about merging two 2-D arrays. I have a program that generate two different arrays interms of binary digits (output file attached) and I wanted to arrange them as below.
First generated array: 1110
 1101
 1011
0111
Second generated array: 0001
         0010
         0100
                         1000
Output should be: 1110
   0001
   1101
   0010
   1011
   0100
   0111
   1000
Thank you.
(2,527 Views)
Accepted by topic author ramutha
Checkout the attached VI
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
(2,513 Views)
Here is one that works with number arrays. It is fast than using strings. Looking at your picture it looks like you are going to be using numbers so this one should be more appropriate
Example_BD.png.
Tim
GHSP
(2,506 Views)
Hi there,
aeastet is right. His example is the right one. I didn't check the picture which was attached. I just read the post and posted the code. Thanks for the post aeastet..:)
warm regards,
Nitzz
(2,503 Views)
Thanks a lot Nitz, the solution is easier than I thought.
(2,498 Views)
Thanks Tim for your help.
(2,497 Views)
Sure no problem and thank you both for the kind words. Always welcome to see.
Tim
GHSP
(2,493 Views)
