Memory Usage of VxWorks - cRIO 9014
Any suggestions how to monitor memory usage in RT on the cRIO itself?
Message 1 of 15
(3,938 Views)
I don't have RT anymore, so I can't confirm this, but have you tried navigating to this palette: RT Utilities >> System Configuration >> RT Software >> System Node, then System Resources property?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 15
(3,918 Views)
This is what I found.   Am I looking in the right place?  Cuz it would appear that I am not.Capture.JPG
Message 3 of 15
(3,890 Views)
I've even used the Quick Drop to search for System Node which I did not find.  I know you said you couldn't confirm, but it sounded like you've done this before or at least seen it before in some form.  So I do appreciate your help, btw.
Message 4 of 15
(3,880 Views)
I think it would be a good idea to inform about what version of LabVIEW and Real Time module you are using.
To get the system property, you can just drop a normal property node on the block diagram and then right click and select the System Config class->System Hardware
Message 5 of 15
(3,855 Views)
LabVIEW 2011 - cRIO 9014
But the following is what I found:  This will work on a RT target?  I don't have the 9014 before me to test at the moment.  Curious, though, what reference do I pass into it?  This VI?    Or is this something I can't test until I can actually deploy it?
Message 6 of 15
(3,838 Views)
I think 2011 and older, you need to use an actual RT status VI. Someone else on here will have to find that legacy VI for you 😕
Cheers
Message 7 of 15
(3,784 Views)
Anyone got any advice on this?
Message 8 of 15
(3,671 Views)
Accepted by topic author DailyDose
You should have access to this palette.
Cheers
Message 9 of 15
(3,666 Views)
The image I attached in an earlier post shows the VIs in my Utilities pallet.  My list of VIs appears to be incomplete based on that link you posted.
Message 10 of 15
(3,652 Views)
