Memory IDL documentation - FlexRIO DRAM
The documentation for the Memory IDL is not very well organized as other NI tools & libraries (think DAQmx).  It would be good to have a set of links so we do not need to piece things together from forums, help, and examples.
There is a lot of stuff on the VST which is great but for those using FlexRIOs there isn't as much.
On Google I search "labview fpga 2015 Memory instrument design library "  the 8th link is relevant:
http://zone.ni.com/reference/en-XX/help/372614J-01/target5devicehelp/idl_memory_overview/
The last statement says:
"Refer to the LabVIEW context help of the Memory Design VIs for more information about the library interface."
These VIs are not in the Functions Palette:
The examples are somewhat helpful but it would be good to have more help in the form of documents.
ALE Consultants
Message 1 of 11
(4,197 Views)
Thanks for bringing this to our attention. I brought this to the attention of R&D and they requested that I file a CAR (#595063). I'm not sure if documentation CARs get reported on new releases but I'm hoping that we can get this fixed in future releases to make the API easier to use.
Message 2 of 11
(4,140 Views)
Thanks, are there any other links you would suggest for this topic?
ALE Consultants
Message 3 of 11
(4,098 Views)
Hi Terry_ALE,
Unfortunately, there is limited documentation for the IDLs. The LabVIEW Context Help will be your best resource for this topic.
Shalini M.
Partner Development Engineer
Alliance Partner Network
Message 4 of 11
(4,066 Views)
I don't have LabVIEW in front of me but I didn't think there was context help, I think I remember putting that in the CAR.
Message 5 of 11
(4,058 Views)
Is there a way to find out if this CAR (#595063) was corrected?
ALE Consultants
Message 6 of 11
(3,455 Views)
It has not been addressed. The Memory IDLs are added to the functions palettes but they still do not have documentation.
Message 7 of 11
(3,447 Views)
I am using LabVIEW 2016 and I do not see the Memory IDL on the palette (I see the others).  Were they removed for 2016?  Where can I get more info on them?
Message 8 of 11
(3,153 Views)
Function palettes are context aware, meaning if a vi is opened under a flexrio target it will have different entries on the function palette than it would if it were opened under an r series target. The 'FlexRIO FPGA Libraries' that is shown in the OP is an example of a menu that would only appear on the palette when a vi is opened under a flexrio target.
Message 9 of 11
(3,147 Views)
Understood, I am working with the FlexRIO, but am missing the Memory IDL in the palettes.  I know it is installed because I can open examples that contain it.
Message 10 of 11
(3,133 Views)
