Measuring in High Frequency: High Sample Rates & Computer Streaming Slow, PS4000.llb
Hai,
Im still a Beginner to LabView and need some help.
I am using Picoscope 4000 Series for the measurements. I am using one of the examples provided by NI, PS4000.llb (PS4000_stream.vi), and discovered that the computer or LabView is very slow, or not showing any data at all, when i change the Sample Rates to 60 M S/s. I even tried at 30 M S/s, i did see some data being stream but really slow.
The problem is i need to measure at the frequency of 30 MHz. As i understood, i will have to set the Sample Rates double the measured frequency.
I think it has to do with the Samples Rate and Number of Samples. or maybe something else.
I would be really glad for the help. 🙂
Nat
(2,692 Views)
Hi NatNeuWe,
can you send me the link to the device driver an t the direct link to the manual(s) you use.
Kind regards,
Philipp K.
AE | NI Germany
(2,577 Views)
As the download page clearly states, the driver is not written by NI and is unsupported. Have you contacted Pico?
(2,572 Views)
Hi Wendler,
sorry for the late reply.
here is the link to the dll from picotech.
http://www.picotech.com/softdownloader.html?zeitfaktor=5m0k3m34k1pp3r&os=drivers&soft=PS4000sdk&pid=...
Somehow i figured it out, i have no problem since. Instead of using PS4000_Stream.vi, i used PS4000_block. To my understanding, this vi does not stream the data directly, but save it in the Scope before sending it to pc.
I hope its the right way, since i have no problem after using a different example.
NatNeuWe
(2,517 Views)
Hi NatNeuWe,
You want to have a look at the webpage below
http://www.picotech.com/education/oscilloscopes/data-acquisition-modes.html
It explains how the data acquisition modes work with Pico Technology devices.
If you require more information please feel free to post on the Pico Technology forum (http://www.picotech.com/support/)
Kind Regards,
Karunen
Pico Technology Technical Specialist
(2,424 Views)
