Measuring frequencies present in an analog signal
I want to measure the frequencies present in an incoming analog pulse signal.
I tried it as shown in the vi using ‘Extract single tone information.vi’ which was showing the value as ‘39m’ I dont understand what is this value. Can someone explain the right way of measuring the frequencies present in the signal so that I can feed them to my bandpass filter limits.
Thanks.
Message 1 of 9
(3,491 Views)
Accepted by topic author GoviRe
You are not supplying any of the timing information needed to do an FFT and get your frequencies.  You need to use Build Waveform and supply a dt, which is your sample rate (seconds/sample).
GCentral
Message 2 of 9
(3,486 Views)
Beyond what crossrulz has mentioned the explanation for the '39m' value you saw is that the FFT will be interpretted as having a sample rate of 1 sample per second in the absence of any other information.
The for loop can be replaced by the simpller loop above it in the image below. This has the advantage that it does not need to allocate memory for the 0,1 array.
Lynn
Message 3 of 9
(3,446 Views)
Now I am able to see the detected frquencies.
and I think the detected pulse signal will have different harmonics of needed frequencies and the 60Hz frequency component. So, before filtering I want to see the different harmonics of frequency components present in the detected signal for which I tried the power spectrum as shown in the attachment.
Can someone explain me a better method to see the harmonics components present in the detected signal.
Thanks.
Message 4 of 9
(3,407 Views)
The signal you connect to the power spectrum VI still has no timing information. You have an array of DBL wired to the input.  Use the waveform you connected to Extract Single Tone Information.vi for the power spectrum input also.
Two other things:
1. You have a large DC component in the signal - DC = 0.071, AC = 0.004. Remove that before doing the other processing.
2. Use a logarithmic Y-axis scale for the spectrum.
Please post your complete VI with some typical data saved as default.
Lynn
Message 5 of 9
(3,400 Views)
Now I am able to see the DC component and frequency of the measured signal.
But I am unable to get the 1)DC fitlered signal 2) Power Spectrum waveform.
I want to see what all the main frequency components present and the harmonic components present in it.So, that I can set a frequency limit of only desired main components.
Attachments:Measured data and vi.
Can someone suggest me of how to do this.
Thanks.
Message 6 of 9
(3,315 Views)
1.  The DC filtered signal Is an ARRAY of Waveforms. Apparently subtracting an array of DBL from a waveform results in an array of waveforms where each element is the original waveform data minus the value in the corresponding element of the array of DBL. That is an array of ~15000 waveforms, each with ~15000 datapoints = 225 M DBL = 1.8 GB.  What you want is to get a single DC value, not an array, and subtract that single value.
2. The Spectral Measurements output is in decibels. The graph Y axis needs to be set to Linear, not Logarithmic. The logarithm of -5 dB is undefined. The Log10 function returns NaN. So most points do not plot.
Here is a simplifed version with the data from the file saved as default in "all rows."  The spectrum shows a significant 50 Hz component and a smaller 150 Hz component (power line frequency?).
Lynn
Message 7 of 9
(3,281 Views)
The acquired analog signal is pretty much filtered as shown in the attached image.
Now I am collecting data for 5 seconds (collecting 2500 samples using collector.vi ) and finding the single tone frequency from it and plotting the measured frequency after 5secs in a waveform chart.
But I am confused with these1)The original detected signal has an amplitude of above 1.6V but the measured amplitude only shows 0.6V and 2) how the waveform chart has a plot plotted over the duration of 5seconds  when the frequency is measured for every 5seconds data I mean shouldn’t  the chart has a plotted value of HeartRate plotted  for every 5 seconds.
Can someone explain a bit about these.
Thanks.
Message 8 of 9
(3,174 Views)
Hi GoviRe,
   Amplitude is generally half of the peak to peak signal strength. Think of a sine wave which has amplitude 1, but swings from 1 to -1. The waveform chart should update every 5 seconds with one new frequency point added. If you want the time axis (x-axis) to display seconds, then right click the chart --> properties --> scales --> multiplier, set it to 5 seconds, or 0.0833 for minutes.
Have fun coding!
Message 9 of 9
(3,167 Views)
