12-09-2010 02:19 PM
My measurement and automation tool only shows a software node. Nothing like hardware, or my devices. I am looking for my comports, since I can't get my HP34401A communicating. To be hones, this might be the serial cable, I'll know for sure tomorrow.
But still, shouldn't MAX give me more info?
I definitively have working comports.
I am running an evaluation version of Labview 2010.
Best regards, Matthijs
12-09-2010 04:44 PM
Have you installed anything from the Device Drivers DVD as of yet?
If NI-VISA hasn't been installed, then you won't see any com ports in MAX. Likewise, if DAQmx hasn't been installed, the DAQ devices won't show up.
12-09-2010 05:26 PM
Also, if you have an NI serial interface device (as opposed to the serial ports on your motherboard, if you have them), you will need to install NI-Serial.
12-12-2010 08:56 AM - edited 12-12-2010 08:57 AM
thanks for the replies. I have NI-VISA installed. But still nothing. Also under the 'tools' menu, I don't see anything for setting up NI-VISA. I've also removed and reinstalled NI-VISA, and that doesn't help. And I tried to 'repair' MAX, equivalent of reinstalling I would say, and that also doesn't help. Still the only thing I see in MAX is the 'Software' node.
My 34401A works by now. I have also installed the Agilent VISA, and I am addressing the 34401A via the VISA resource name ASRL::COM7. And now I am not sure if this ASRL::COM7 is going to the Agilent VISA or the NI-VISA. But it sure works perfect.
But I would still like to have MAX working properly! So if anyone could shed some light on this I'll be very gratefull!
Thank you, Matthijs
12-13-2010 01:54 AM
Dear Matthijs,
It is possible that there is a problem with your MAX data base ; can you try the link?
Please let us know the result,
best regards,
