04-03-2013 01:58 PM
When I create an installer and place on a new machine I do not get the drop down capability to choose the device. Am I missing an additional installer? I have MCC's Instacal program installed on the target machine and it will show the attached boards. I close Instacal and open the stand alone labview program and it does not work. Everything will work when its is run on the development computer.
04-04-2013 09:01 AM
The problem is most likely that your project did not include a file named (similar to): ULx_Browse110.LLB. It is located in the following folder:
C:\Program Files\National Instruments\Shared\Ulx\Browse
There is a different named file for each LabVIEW version. For example: 110 = Version 11
Another cause is that your target PC has multiple copies of a file named CBW32.DLL There should be only one file by this name on the hard drive, and it should be the one that the InstaCal installer itself puts in the DAQ folder.
07-10-2013 07:24 AM
Mr. Brent.
I have the same problems with a 1208LS. I had include the ULx_Browse110.LLB. When I built (application.exe) I am sending the ULx_Browse110.LLB file to "Always include", and after I built the Installer. But after when installed the soft (stand-alone) not find the file (ULx_Browse110.LLB) and the program not recognized the 1208LS DAQ board. How should be attach the ULx Browse rightly?
07-10-2013 10:10 AM
Be sure to have installed InstaCal on the target machine. Also be sure to have run InstaCal at least once, so that the USB-1208LS board is recognized in InstaCal. Then close InstaCal and keep it closed. Then launch your LabVIEW runtime.
