Measureing Time Delay of two Waveforms
I noticed that Labview has a number of waveform measurements VIs. I would like to be able to measure the time delay between two waveforms. Does such a vi exist in the tool kit?
Note: I'm using an older version of LabView 2009.
(2,611 Views)
Hi Steve,
you should explain the term "delay" in more detail…
- Each waveform has a t0 part. You can subtract both to get the delay between them…
- When you want to measure delay between certain parts of your waveform you might consider the cross correlation function…
(2,605 Views)
A scope delay between two signals. Just like you would measure a rising/falling edge to a rising/falling edge on an oscilloscope.
(2,600 Views)
Sounds like cross correlation (for arbitrary signals)!
For digital signals you might consider searching edges and subtract their timestamps…
(2,594 Views)
