01-13-2011 09:40 PM
Hi there. Does anyone know how to obtain the weight and speed of an object by using the waveform obtained from the oscilloscope when we roll the object over a fibre.
01-14-2011 05:49 PM
Weight would be difficult to measure, since amplitude will vary with many other parameters, but you could try to mapping amplitude with weigth.
For speed, you should use 2 fibers, and speed = distance between fiber/time between peaks.
01-16-2011 12:38 AM
okay i will try on the measurement of speed. thank you. but what do you mean by mapping amplitude with weight?
01-16-2011 12:57 AM
Experiment with different weights noting the amplitudes you get. From this data you may be able to find a formula that gives you weights corresponding to amplitudes. As was hinted at earlier though there may not be a direct formula. For example, the speed the weight is travelling at may impact the amplitude you read.
Rgs,
Lucither.
