Max Xl Sheet in single workbook.
hi,
      i generate the report in XL File using ActiveX controll(Not in RGT).i want know about maximun sheet in single workbook.i search in google they say it's depence on memory no limitation.but i  able to open maximum 200sheet only.if itry to open 201sheet it give error.
(2,417 Views)
Do not attach a picture of your code -- attach the actual VI, itself.  With the VI, we can "play" with it, study it, maybe figure out why it is generating an error, and maybe figure out a fix.
If all you want to do is to tell the World you can't do something, attach a picture (to prove it).  If you want help, provide something we can use to help you (like LabVIEW Code, manifest as a VI).
(2,412 Views)
