07-02-2012 09:06 AM - edited 07-02-2012 09:10 AM
Hello:
I need to run the stepper motor, the problem is that the Logic (MATLAB code) will be interfaced by the "dSpace (Control Desk NGV version 4)", which does not support the Stepper motor block, available in the Simulink Library.
07-03-2012 07:07 AM
Hi Mr Shayan,
This problem you are describing seems to be related only to Matlab and Simulink. I would suggest that you post on the Mathworks forums as there you are likely to get an answer to your query. This forum is focused on LabVIEW problems and discussions. The link for the Mathworks forums is below:
http://www.mathworks.co.uk/matlabcentral/answers/
If you have a specific LabVIEW question please do feel free to ask it here as we may be able to help but it seems your question is most suited for Mathworks.
Kind Regards,
07-16-2013 01:23 AM - edited 07-16-2013 01:33 AM
Please sorry i was trying to post my probem
07-16-2013 01:36 AM
You should create a new thread for your question, when its not related with an existing topic.
07-16-2013 02:12 AM
how can i create a new thread sir?
07-16-2013 05:16 AM
Hi CHAFAH,
You can go here a add a question
http://www.mathworks.de/matlabcentral/answers/
just as simple as that
04-08-2014 08:02 AM
Hi all Help me
I was doing something on simlink but i want to chnage the value of simlink, that value is in matlab's graphic interface. How can i change value of simlink value and how to give value from Matlab's Graphic Interface.
04-08-2014 08:03 AM
Hi all Help me
06-12-2014 10:33 AM
Bonjour,
Comment peut on lire des données du capteur avec le matlab simulink ?
