08-13-2006 07:00 AM
08-14-2006 12:49 PM
Hello Michael,
Are you actually running this application in the LabVIEW Real-Time OS? The Matlab Script uses ActiveX calls and only works on a Windows Operating System. Calling the dlls in Call Library Function Node would be a more difficult that using the Matlab Script Node. You will need the function names in the dll as well as the parameter list.
Good luck
Steven T.
08-16-2006 10:43 AM
08-17-2006 09:41 AM
mishklyar,
That is a great question. DLLs will be run in the runtime environment of the program that created them. So calling the DLL in C will give you a good idea of the performance of the DLL. When calling the same DLL in LabVIEW, you should get similar behavior with regards to speed. So in short, you should see a performance increase by calling the DLL compared to your current method.
I hope this helps,
Steven T.
