06-21-2016 07:24 PM
I am using match regular expression with the following expression. It is only able to get any numbers that are not single digits. I want to grab any values that are between >< in the string and create an array.
So
<ENV_SCALE>182</ENV_SCALE>
<TXFE_GAIN>2</TXFE_GAIN>
would output
182
2
Any help would be appreciated. I've attached what I have so far. Right now I still have the >< and it can only grab numbers that are not single digits.
Solved! Go to Solution.
06-21-2016 10:10 PM
06-22-2016 01:37 AM
Since it is solved, its fine. But please try to have the question in a single thread
