Match Pattern Algorithm vi - No returned score when failed
I'm building a vi to do the pattern matching comparison between source image and template image.
However, there is no values, including score being returned Matches & Calibrated Matches indicators when the comparison fails.
With the passed results, the score value is returned in the both indicators.
I will need to the score to do some fine tuning when there is a failure.
So kindly need the advise from the expert to address this problem
Thanks.
Message 1 of 1
(2,102 Views)
