Manually scale X and Y axis while VI is running
I am trying to use property nodes change the scale of the x and y axis while the program is running (ie for the x-axis it would be a seconds/division control). However, everything I've tried has given me an error saying that I have an unwired or bad terminal somewhere. I think it may have to do with using a double waveform graph and I have to convert it somehow?
Any tips and help is greatly appreciated.
(3,998 Views)
Your property node of the graph reveals FOUR properties to write, but you connect only TWO (XScale.Maximum and XScale.Minimum). So either remove the other two (XScale.Range and XScale.Increment) by right-click directly on them and select Remove Element, or connect some valid data.
Norbert
Norbert
Expert: Geometry
(3,963 Views)
(following up from Norbert's Post)
... or when you make a Property Node for Waveform Graph 3 and Select Property, go to XScale, Range, Minimum (not XScale, Range, All Elements), drag down to get another Property and set it for XScale, Range, Maximum.  It should look like this:
(3,957 Views)
