Managing/Preventing Simultaneous Access to Same VISA port
I currently have a VI with three parallel loops: a loop for the user interface with an event structure; a loop for data collection; and a loop for data plotting.
The data collection loop writes to the serial port to ask the device to send an updated sensor reading. The device sends the updated sensor reading, and the data collection loop reads the devices reply.
I have a situation where the user interface loop also needs to 1. write to the same device (via the same port), 2. read the reply, and then 3. write again using data from the reply and user input. My problem is the user interface loop is reading the devices reply to the data collection loop rather than the reply to the user interface loop.
So the problem looks like:
data collection loop: How hot is it?
device: 30 Celsius
device: 30 Celsius
user interface loop: What color is the sky?
device: 30 Celsius
user interface loop: Ok! the color of the sky is 30 Celsius.
device: blue
I am tempted to pursue a solution where the user interface loop somehow pauses the other two loops while it is writing and reading to the VISA port, but I doubt this is the proper solution. My code is rather large, but I can try to post it if necessary. I remember seeing posts from people with similar problems, but I seem unable to find them today. Thanks in advance for the help!
Message 1 of 14
(2,756 Views)
I have used Semaphors in the past, see my attachment here:
Upper loop polls for data at regular intervals.
Lower loop sends configuration commands as needed.
This is just sandbox code I was playing with to prototype a larger app.
http://forums.ni.com/t5/LabVIEW/User-specified-DAQ-interruptions-instrument-control-through/m-p/2604...
-AK2DM
Message 2 of 14
(2,750 Views)
Hi Ben,
I suggest to put all VISA Port communication in it's own loop and sending commands and data via queues/notifier to your UI/DAQ loop.
This has the advantage of creating a single loop handling all the device communication, and so being able to do all things in correct order! Sharing a single resource (like your VISA port) to several threads/loops for random access will always be tricky…
Message 3 of 14
(2,744 Views)
Accepted by topic author _Ben_
Ben's famous Action Engine Nugget is always a good read. http://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/m-p/503801
Now that you went through that let's expand on a specific style of AE that I call a Resource Module.  A RM exposes only those functions that a given application needs to perform using an external resource while protecting "Critical" code sections.  In your example even though the VISA operations block multiple callers from writing simultaineously, you failed to protect the critical "Query" operation so reads got responses to the wrong caller.  The "Query" is critical and needs to block access to other operations until the query is complete.
Take look at this "Very Basic" RM implementation that does protect the critical query operation:
"Should be" isn't "Is" -Jay
Message 4 of 14
(2,720 Views)
Jeff, I like that! But just one small question - I'm sometimes not very good at acronyms - what's the FBN in your diagram?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 5 of 14
(2,705 Views)
Cameron
Feedback Node.Smiley Wink  You could also use a Shift Register and a while loop but, the FBN has some slight advantages that are out of scope for this thread.
Message 6 of 14
(2,700 Views)
I am having trouble with your snippet but decide to start a new thread
=== Engineer Ambiguously ===
Message 7 of 14
(2,693 Views)
@RTSLVU wrote:
What am I doign wrong here? I can not seem to figure out how to use a snippet.
Jing here
A "Jing on draging to your desktop then draging to your new BD.  (Sorry for the large screen- you may need to scroll to get the full picture):smileywink:
Message 8 of 14
(2,682 Views)
Jeff, thank you for your reply. You very eloquently described my problem, and I'm excited to implement the solution you suggested. I am actually working on a different project at the moment, but hopefully I will be able to get to this tomorrow. I have a few follow up questions, but I will wait to ask them until after I've read and fully digested Ben's Action Engine post.
I appreciate everyone's help!
Message 9 of 14
(2,668 Views)
There is also a very good explaination of "LV2 style globals" and race conditions and "Critical" code (Didn't Darren N Write it?) Somewhere (in the community?).  I can't find it  So
Kudos to anyone with the link.
Message 10 of 14
(2,659 Views)
