01-17-2007 06:58 PM
01-18-2007 01:17 AM
Hi
Have a look at this document: http://zone.ni.com/devzone/cda/tut/p/id/3303
To answer your questions:
1. Yes and no. In general, the application builder will include the complete vi hierarchy of vis you created and which are static. If you call vis dynamically, you have to include them separately.
2. If the software is already there, is should not be necessary to reinstall it.
3. Generally you do not have to make entries in the registry.
Finally, you have to install the apropriate LV runtime engine. Otherwise your exe won't run.
01-18-2007 08:54 AM
01-18-2007 09:11 AM
01-18-2007 09:29 AM
Do you know which of the three?
TeBlues
01-19-2007 12:10 AM
01-19-2007 08:35 AM
I just used visa reads and writes on the GPIB, on this one.
Thanks a bunch for the help
TeBlues
