10-09-2014 09:32 AM
I have a 1D array and I would like to make a 2D array from it in the following order
1D array: 1 2 3 4 5 6 7 8 9 10 11 12
if Rows=4 then the 2 D array shoudl look like this
1 5 9
2 6 10
3 7 11
4 8 12
and if Rows=3
1 4 7 10
2 5 8 11
3 6 9 12
Could you please let me know how cna I do it in LabVIEW? , Row number and 1D array are the input parameters
Solved! Go to Solution.
10-09-2014 09:36 AM
Reshape Array.
You may or may not need to use a Transpose Array after that.
10-09-2014 10:07 AM
And what should happen if the number of array elements is not divisible by the number of rows (pad with zeroes? truncate?)
10-09-2014 10:09 AM
Thanks OrioleFan
Are you sure Reshape array will do that?
because if I pass the 1D array and 3 for row to this function it will output .. rows dimention =3 column=4
it will pass
1 2 3 4
5 6 7 8
9 10 11 12
but what I expect is this
1 4 7 10
2 5 8 11
3 6 9 12
10-09-2014 10:12 AM
Hi althebach
It is always divisible.
10-09-2014 10:16 AM
To give anything that handles that task well requires an answer to altenbach.
You're going to end up wanting to use loops of some type and building your array. But, you need to know how to handle that corner case. What do you do if the number of rows s 5?
10-09-2014 10:17 AM - edited 10-09-2014 10:23 AM
As OriolesFan already said, reshape array is the correct function.
Here is the more general solution that pads the output array. if the elements are alway evenly divisible, you can leave out the "sign" and "add" function and just wire the IQ output to the upper size terminal of "reshape array". (and generate an error if the remainder output is not zero ;))
10-10-2014 08:06 AM
Your solution was given by the first response - you do need to use transpose array. If you take a twelve element array and reshape to three rows by four columns, this happens
goes to
1 2 3 4
5 6 7 8
9 10 11 12
This is not what you want. However, if you reshape to four rows and three columns, you get
1 2 3
4 5 6
7 8 9
10 11 12
Which is still not what you want, but a Transpose then produces
1 4 7 10
2 5 8 11
3 6 9 12
which is exactly what you want.
03-02-2015 11:33 AM
Thanks Altenbach. I took your code and made it a polymorphic supporting 20 different data types, and added a few more features, and posted it over on LAVA.
https://lavag.org/topic/16226-new-array-vi/page-2#entry113339
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
