Your right. I apologize. My method is for the non-Express vi's. So with the Express vi's you should have a MS Office Report vi that uses a template. If you right click on this and select properties, a configuration window appears in which there is another window where you can navigate to the path of your template. As stated before, your report template must reside at the same location on the target machine.
