MS Access LIKE condition returns zero records
When using the "WHERE" clause with the "LIKE" condition with the database connectivity toolkit, I get zero records returned from my Access database. Running the exact same query text in MS Access itself returns the correct number of records.
I'm using the "DB Open:", DB Execute Query" and then the "Fetch Recordset Data" VIs.
Replacing the LIKE with a simple "=" will return the one matching record as expected.
Is there a known issue using the "LIKE" condition?
Bill
LabVIEW 2011 SP1
(2,595 Views)
Accepted by topic author BillMe
While old, this may shed some light:
http://forums.devarticles.com/microsoft-access-development-49/like-operator-not-working-with-ms-acce...
Your LIKE statement may not be properly formed.  Insida Access, the connection is different than through ODBC, and the like wildcards are different as well.
(2,591 Views)
You are correct. The wildcard character is different for ODBC, should be '%'. Thanks.
(2,588 Views)
