MCP2210 DLL and LabVIEW 2014
Can I have some help for using the dll of the MCP2210 breakout board within a vi in order to output hexadecimal chain through the SPI serial bus and some digital signal to an evaluation kit board ?
I have found some links here, but they are for older version of LabVIEW and DLL.
Thank you for the answer.
JPV67
Message 1 of 21
(5,062 Views)
It doesn't matter that the examples are for an older verison of LabVIEW and DLL.
Concept of *how* to do it remains the same.
Message 2 of 21
(5,039 Views)
Well, so , how  ? Have you an idea ?
It would be more useful for me, thank you.
Message 3 of 21
(5,000 Views)
You said that you have found some links. FOLLOW them.
Message 4 of 21
(4,992 Views)
That was a useless reply.
Message 5 of 21
(4,822 Views)
I have a similar problem.
Message 6 of 21
(4,820 Views)
Hello LYNNS,
I am happy (!) to see that I am not the only one who have difficulties to use MCP2210 DLL with LabVIEW.
Because of the no ( stupid ?) answer, I change my project and decide to use LabVIEW with Arduino UNO via the LINX programm :
https://www.labviewmakerhub.com/forums/viewtopic.php?f=12&t=528&p=3300#p3300
Now I developp an other application with the good help of samkristoff !
Hope this can help you, good luck !
Message 7 of 21
(4,797 Views)
If you want a good answer, ask a good question. "Can I have some help?" is not a good question. Post your code, explain what doesn't work, include the text and error code for any errors that occur.
Message 8 of 21
(4,774 Views)
@JP67 wrote:
Hello LYNNS,
How is the "difficulties" of MCP2210 DLL any fault of the LabVIEW community here????
It is a DLL written by Microchip. Blame them them instead.
And for your information, no one here is under any obligation to help you with YOUR project.
It is YOUR project. Not our project.  Talk about being a narcissist.
Message 9 of 21
(4,767 Views)
Thank you for the input. The only problem I have is that I need to upgrade from 2011 to 2013 to run.
Message 10 of 21
(4,749 Views)
