08-28-2013 08:35 PM
I am getting the following errors when I try to open up MAX:
The niRemPXI.mxx plug-in caused an exception in the CmxProviderWrapper::BindPrimary function in the NIMax process.
See these files for details:
C:\ProgramData\National Instruments\MAX\Logs\20130828_180211-NIMax-00001484.log
C:\ProgramData\National Instruments\MAX\Logs\20130828_180211-NIMax-00001484.dmp
The niVISAui.mxx plug-in caused an exception in the CmxProviderWrapper::Finalize function in the NIMax process.
C:\ProgramData\National Instruments\MAX\Logs\20130828_180213-NIMax-00001484.log
C:\ProgramData\National Instruments\MAX\Logs\20130828_180213-NIMax-00001484.dmp
The exception occurred in the NIMax process in the function CmxExecutionThreadPool::DoWorkNonUI.
C:\ProgramData\National Instruments\MAX\Logs\20130828_181648-NIMax-0000173C.log
C:\ProgramData\National Instruments\MAX\Logs\20130828_181648-NIMax-0000173C.dmp
I have tried repairing MAX software unsuccessfully. How to fix this issue ?
Jeet
Solved! Go to Solution.
08-29-2013 10:02 AM
Hi Jeet,
WHat version of Daqmx are you using? Other people with the same problem have solved the error by installing the latest version of Daqmx.
08-29-2013 10:20 AM
I'm not sure what version of MAX you are running, but you may want to upgrade to 5.5.
08-29-2013 11:46 AM
DAQmx version is 9.6.0. MAX version is 5.3.3
NI System Configuration Runtime 5.3.3
08-29-2013 11:49 AM
Even though NI-MAX does not open up and giving me errors, I opened up labview and placed a DAQmx reset device VI and connected a constant at its input. The constant does show all the daq cards (connected in my PXI sytem) in the labview.
What does this mean ? Can I continue with the development even though the MAX does not open up ?
Another NI engineer recommended trying to install the NI System Configuration utility (http://joule.ni.com/nidu/cds/view/p/id/4086/lang/en )
since it does appear that drivers are currently working correctly. This installer includes MAX and a few other utilities but should not affect driver installations.
08-29-2013 12:49 PM
Correct installing NI System Configuration 5.5 should only upgrade MAX. It does not contain any drivers.
08-29-2013 01:06 PM
Installing NI System Configuration utility fixed the problem for me.
Jeet
10-17-2013 02:34 AM
i have had the same problem with MAX after installing LV2012 SP1 Developer Edition (Setup without CVI).
Try to start MAX and got the error messages:
Context where exception was caught:
Func: CmxProviderWrapper::BindPrimary Args: plugin=niRemPXI.mxx niim=0314FC24 outer=01E30538
1. try to rename that DLL mentioned in the post above. Even after renaming that DLL i got:
Func: CmxProviderWrapper::BindPrimary Args: plugin=niRemPXI.mxx niim=0350FC24 outer=01D7ECE0
2. try to repair my MAX 5.4 --> NO
3. try to repair my LV2012 SP1 setup incl. f5-Patch --> NO
All that didn't help.
4. Upgrade to MAX 5.5 --> YES
After that MAX starts without any error messages. Hope that helps anyone.
Stefan
