MAX 5.3.1 removed Device numbers from SCXI-1600
Meas. & Auto. (MAX) 5.3.1 removed Device numbers from SCXI-1600
Old system - Works! :  Labview 9.0 on Dell laptop win XP.
I have a client that uses multiple laptops & multiple SCXI chassis with 1600 USB DAQ controller mod.  Each time a “new” 1600 was used a new SCXI chassis was installed and the new 1600 was given the next device number (Ex. Dev1, Dev2, Dev3).  I would use the DAQmx  System class Node, DevNames property to see which device I had and go from there.  (Note:  this still worked on LV ver. 11 & MAX  5.x ?)
I upgraded to LV 2012 (32 bit) fix#3 with MAX 5.3.1 and the Device number (Dev1) is now replaced with  “Mod1”!  I know I could program a workaround, but I would rather have the names go back to the old Device numbers!
(2,211 Views)
Accepted by topic author Tom_Brackman
Hi Tom,
Thank you for posting. I recently noticed this problem and reported it to R&D as CAR #362997. The change of SCXI-1600 default name from "Dev1" to "Mod1" seems to have been introduced in NI-DAQmx 9.4. I can't guarantee anything, but the fix is currently on track to go into the next version of NI-DAQmx (excluding patch releases).
For now, I'm afraid you'll have to work around the problem. Here are a few ways you can do that:
  • Manually rename the device in MAX on each system.
  • Programmatically rename the device using the NI System Configuration API. Look at <LabVIEW>/examples/nisyscfg/Rename Aliases.vi for an example.
  • Change your application to use a different default name or to detect the device differently (e.g. using the DAQmx System >> DevNames and DAQmx Device >> ProductType properties).
Brad
Brad Keryan
NI R&D
(2,201 Views)
Brad,
Thanks for the reply!
Tom
(2,167 Views)
