02-14-2013 08:23 PM
My front panel has three tabs that are populated with lots of boolean indicators. What's the best way to minimize the mess on the block diagram. I'm also using references for a number of boolean controls as well.
02-14-2013 08:55 PM
That really depends on what you are using them to indicate. Arrays and clusters are the first things that come to mind. If they represent some kind of image or visual display as opposed to individual signals an intensity graph might be a consideration.
Lynn
02-14-2013 11:52 PM
The best way is use one array of boolean for each tabs as johnsold suggested. That will make the front panel clean and in the block diagram you can mangae them easily.
02-15-2013 06:57 AM
That will work if the indicators are together in a line. My indicators are spread out over a graphic. Perhaps if I make the graphic and the many indicators part of the control?
02-15-2013 08:28 AM - edited 02-15-2013 08:29 AM
You can put them in a cluster, customize the cluster to make its size the same as the graphic and make its background transparent and then put the cluster over your graphic (assuming you don't do any graph manipulation ion the GUI like moving cursors).
note: set the cluster autosizing to none.
Ben64
02-15-2013 08:55 AM
Addendum, if you use the cluster idea, you can use cluster to array to handle it with the nice array functions when needed.
/Y
02-15-2013 10:36 AM
Please post your VI along with an indication of what you like and do not like about the way you are doing it now. Otherwise we are guessing about what you want.
Lynn
02-17-2013 10:40 PM
Post your VI in 2011 compatible format. Will deal with it.
