I started trying to vary the rate at which data is written to a file. I thought a loop would be used for this with a variable delay which worked from a file write perspective, but when I use longer delays, the loop seems to execute but other parts of my UI don’t update anymore. I’ve tried the loop inside and out of the while loop. I was going to include calculations inside the loop to store a new file every 24hours, but I have since discovered the VI already has the functionality in the dialog configuration.
What is the basic thing I’m missing about parallel operation and loops? I have other tasks where I will want to vary a duty cycle on an activity and I’m obviously doing it wrong.
