09-08-2016 08:23 PM
09-08-2016 08:50 PM - edited 09-08-2016 08:52 PM
No attachment.
Be sure to include your actual VI and not just a picture.
Also, exactly what does "the file format to be changed and divided based on channels with their respective data" mean? Provide an example of how you want it to look.
09-08-2016 08:51 PM
Thank goodness you forgot to attach the picture. Do not attach a picture! Instead, attach the actual VI so we can inspect it, edit it, see "behind" the Case Statements, even try out some of the code and figure out what it does.
We need to see the code in order to understand it and make suggestions.
09-09-2016 12:15 AM
As suggested by others its always better to share the code which you have tried, so that iys easy to debugg and provide you solution.
to my knowledge and, if i try to get something from your explanation you can use TDMS File format and you can store the values in different sheets.
http://www.ni.com/tutorial/9334/en/
09-21-2016 08:17 AM
09-21-2016 08:19 AM
