05-06-2014 03:54 PM
Hi
I am using a cRIO 9012 together with NI 9215 16bit differential Analog input module. I try to measure voltages and log them to disk and I followed the example found at "Getting Started with CompactRIO - Logging Data to Disk". However, running the RT_VI, I receive an error saying "LabVIEW could not load the TDMS file component, -2519 error". As far I checked, I have excactly the same code and I have started from scratch to be sure.
What goes wrong? Is there any problem with the FIFO ?
05-06-2014 08:52 PM
Judging from the error code. It's not the problem with the FIFO but it seems like the TDMS shared library on RT is not compatible with LV. You can try reinstall LV RT on your compactRIO.
