04-18-2017 01:16 PM
04-18-2017 01:39 PM
Hi Rocky,
when I added a write to measurement file, a file is never generated.
Do you get any error messages? Maybe something like error 7?
Where do you try to save the file? (You know the cRIO is a computer of its own and has its own C: drive? You know the cRIO cannot access your PC's harddrive? You have studied the example projects explaining how to transfer data from cRIO to PC host?)
05-14-2017 02:17 PM
Hi, i encountered a similar problem a while back, when trying to upload data to cloud platform for distributed computing application.
The only way for solving your situation to create a " Shared Variable " within your project file for the variables in your host profile then use on one of the instances of the shared variable in the PC environment for datalogging. Then in the PC environment you can use the shared variables to write data in the measurement file.
As you mentioned you are a Novice, i recommend you to watch a few tutorial videos on using shared variables, trust me its extremely simple.
Best of Luck.
05-23-2017 09:26 AM
Yes I found ALL my logged data on CRIO's drive. even though I had changed the file paths I did not realize it was logging the data on CRIo. Thanks!
