This question is a bit difficult to explain, but I'll try.
I have a main program (main.vi), and a sub vi (setup.vi) that loads the front panel in order to do setup. The setup.vi has the option to "save settings", in which it writes all of the controls to a .txt file. When I click "done", the setup.vi builds a cluster with all of the parameters in order to easily pass all of the information in to main.vi.
Now, when main.vi loads, I want it to be able to read the default setup from setup.vi, and build the same cluster from that data - and I am having a difficult time figuring out how to do it. I have attached the sub-vis that setup.vi uses to both save and load the controls. They are fairly simple.
