Loading a Previously Saved Task into LabView
I have created a digital generation task in LabView and saved it using DAQmx Save Task.vi. I am able to open and run my task in Measurement and Automation Explorer. Now I am wondering if it is possible to load this task back into LabView and run it in a new program. Can I do this with the task saved from DAQmx Save Task.vi or would I need to go about it differently? Where would I start loading the task in terms of vi's?
Thank you for your help.
(2,278 Views)
(2,266 Views)
I am actually not asking the same question as before. Previously, I was having problems using a LabView-created task in MAX. Now I am attempting to create a task in LabView and bring it back into LabView on a separate VI. I have found the answer, though.
https://decibel.ni.com/content/docs/DOC-15842
(2,246 Views)
