06-08-2015 10:46 AM
You can use a tab control as the selector for your different UI VIs with a subpanel - https://decibel.ni.com/content/docs/DOC-42925
06-09-2015 06:25 AM
Hi all,
Thanks for your time.
Peter,
I am not quite sure how to go about creating a cluster of buttons instead of tab control and use an array of subpanels. I need a little more help on this.
Mike,
I could open the document finally. It was really insightful. I was able to understand things which i never knew. I am not sure how i can create multiple subpanels in the same window showing different things.
Sam_Sharp,
I ended up in this thread after reading the document you had posted https://decibel.ni.com/content/docs/DOC-20625, i tried to use this in my application. i replaced the VI's. WHen i run the program, the front panels which i call doesnot seem to work.
I am not quite sure if i make you guys understand about the problem i am facing, Excuse me if i am not clear about anything.
06-09-2015 06:35 AM
06-09-2015 06:41 AM
06-09-2015 07:12 AM
Hi Mike,
Is it the same blog you mentioned in your previous post i should refer to. Because I was able to open that in my home. But there is a problem in my workplace.
06-09-2015 07:56 AM
06-09-2015 10:38 AM
Hi Mike,
I tried doing it this way, i have attached the Subpanel prog and one of the front panel VI (VIBRATION SENSOR) which i am inserting. The Subpanel program throws a pop-up(Not enough memory to compute this operation) after a duration of approx 5 mins, and when i close the pop-up the program runs fine. I wonder if this issue is created by the subpanel prog or the individual VI's which i am calling.
I have not attached few dependant sub vi's for VIBRATION SENSOR vi.
