03-23-2015 09:15 AM
I know it's possible to load all of the subvi into the sub-panel, however, is iti possible to load a pane, or an individuall graph of a sub-vi into the main vi's subpanel?
Solved! Go to Solution.
03-23-2015 09:17 AM
03-23-2015 09:20 AM
so basically I have two options:
load the whole sub-vi and hide the controls and indicators I don't want visible (make them invisible)
or output the graph string to another subvi having the necessarily displays and load that subvi into the subpanel?
03-23-2015 09:22 AM
03-23-2015 10:34 AM
oh, so one can load a subpanel of a subvi into a front panel of the main Vi?
03-23-2015 10:38 AM
03-23-2015 01:07 PM
one can load a whole sub-iv into the front panel of the main vi, - this I know.
can one load a sub-panel of a sub-vi into a sub-panel of the main vi - this I am asking!
03-23-2015 01:12 PM
I think you can stop focusing on the "sub", just put any VI into a subpanel. You can just put a VI into a subpanel, nothing else.
Your problem might just be to redesign your initial VI to also have a sub panel that includes a VI showing only your graph, that VI you will be able to put it into any subpanel of different VIs.
03-23-2015 01:40 PM
great point, thank you
