Load a pane of a subVi into SubPanel of a Main Vi
I know it's possible to load all of the subvi into the sub-panel, however, is iti possible to load a pane, or an individuall graph of a sub-vi into the main vi's subpanel?
Message 1 of 9
(3,462 Views)
Hi rsmrostov,
the function is named subPANEL so it loads the PANEL of the subVI…
No, you cannot load a single pane or graph into the subpanel container!
Message 2 of 9
(3,460 Views)
so basically I have two options:
load the whole sub-vi and hide the controls and indicators I don't want visible (make them invisible)
or output the graph string to another subvi having the necessarily displays and load that subvi into the subpanel?
Message 3 of 9
(3,456 Views)
Hi rmsrostov,
3rd option:
place the graph on the FP of the subVI so it is the only control/indicator you can see in the subpanel container. (Hide scrollbars…)
Message 4 of 9
(3,453 Views)
oh, so one can load a subpanel of a subvi into a front panel of the main Vi?
Message 5 of 9
(3,430 Views)
Hi rmsrostov,
So do you or don't you know?
Message 6 of 9
(3,426 Views)
one can load a whole sub-iv into the front panel of the main vi, - this I know.
can one load a sub-panel of a sub-vi into a sub-panel of the main vi - this I am asking!
Message 7 of 9
(3,413 Views)
Accepted by topic author rsmrostov
I think you can stop focusing on the "sub", just put any VI into a subpanel. You can just put a VI into a subpanel, nothing else.
Your problem might just be to redesign your initial VI to also have a sub panel that includes a VI showing only your graph, that VI you will be able to put it into any subpanel of different VIs.
Message 8 of 9
(3,410 Views)
great point, thank you
Message 9 of 9
(3,395 Views)
