05-26-2010 10:55 AM
I built a primitive little scripting language in LabVIEW that makes calls into a state machine. The listing for the langage is shown in a Listbox control. As the execution occurs, the listing highlights the current line of execution, and keeps the listing in the window using the "Top Row" property. All was good.
Then, a very clever user built a script generator. Scripts can now be exceedingly long, and (despite taking an I32), the Top Row property starts erroring at a value of 32k.
Are there any purely UI workarounds to keep my listbox scrolling? (I'd rather not have to tinker with my scripting language any more...)
Joe Z.
05-26-2010 01:42 PM
11-07-2012 09:50 PM
I also tripped over this "limitation". Any chance this gets resolved? The data type of this property is I32 so why limiting to I16? And a note in the documentation also can´t be find.
11-08-2012 12:26 AM
Probably not, at least as long as NI isn't really aware of it and consider it a bug. I would suggest you go over to the monthly bugs thread in the breakpoint board and add a link to this thread with a brief explanation of the problem. This should get NI to look at it.
Personally, I would agree it is a bug, but a relatively minor one, and I'm not sure increasing the number of rows is a good idea. It's possible that updating the documentation to reflect this limit is the best solution.
09-17-2014 03:50 AM
So, I have a similar problem. I have an error when I try to set a value greater than I16 to the listbox "top row" property. I use LabView 2012, version 12.0f3 (32bit).
09-17-2014 12:26 PM
Then do what I suggested above and use a multicolumn listbox instead.
Another alternative is to hide the scrollbar and create a separate scrollbar control. That way, instead of putting 50k elements in the listbox, you just use the value of the scrollbar to get a subset of the array data and put it into the few elements of the listbox which are actually visible. A bit cumbersome and it wouldn't be necessary if this issue didn't exist, but I would say that a listbox with that many elements shouldn't really exist in the first place.
09-17-2014 01:46 PM
Here is an example of how to use a virtual multicolumn listbox. The same idea can be applied to a normal listbox, but it is basically what tst suggested. A display of data, that changes as a vertical scrollbar changes to give the appearance of one large table.
http://lavag.org/topic/15289-virtual-multicolumn-listbox/
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
