05-07-2010 10:08 AM
are there any plans to deliver an x86_64 (amd64) version of the Labview run-time engine ?
I just made an unsuccessful attempt to wrap it with the latest version of nspluginwrapper (1.3.0):
the outcome died with SEGV (backtrace from LabVIEW_Failure_Log is pasted below).
Thanks.
Francesco Prelz
INFN - Milan, Italy
-------- contents of failure log follow.
#Date: Fri, May 07, 2010 04:43:25 PM
#Desc: LabVIEW caught fatal signal
9.0 - Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x0x4
#RCS: unspecified
#OSName: Linux
#OSVers: 2.6.33.1
#OSBuild: 132641
#AppName: lvrt
#Version: 9.0
#AppKind: AppLib
0xF66B775C - <unknown> + 0
0xF66AF29C - __cxa_throw + 5C
0xF5E88A18 - _ZN2ni8variable10NiTaggerLv3getEv + A8
0xF5E9D04E - _ZN2ni8variable6SharedC1ERKNS_3dsc6VectorINS2_8SmartPtrINS0_12IFeaturePackENS2_16AddRefCopyPolicyIS5_EENS2_23RefCountedReleaseP + 4E
0xF5ED4110 - _ZN2ni8variable15VariableManagerC1Ev + 1760
0xF5ED4F82 - _ZN2ni8variable15VariableManager10initializeEv + 32
0xF5EEB287 - _ZN2ni8variable18InitializeVariableEv + 67
0xF5345A1C - _Z7InitAppv + D8C
0xF534BEEC - <unknown> + 0
0xF534E646 - _Z15LVMainEventProcP6WEventi + 2476
0xF57D125D - <unknown> + 0
0xF57E069B - WSendEvent + 2FB
0xF507C038 - _Z13InitializeAppi + 78
0xF507AF65 - _Z6MGMainiPPc + 105
0xF507B24A - _Z14CommonUnixMainiPPcS_ + 1BA
0xF507B2D4 - LVRTMain + 24
0xF507BF2F - _Z11SysUIThreadPv + 2F
0xF61AE54F - _Z15ThreadCoverProcPv + 4F
0xF71E4195 - <unknown> + 0
0xF71574CE - clone + 5E
05-12-2010 10:39 AM
Ciao Francesco,
as for now NI only supports 32bit x86 platforms on Linux.
You can take a look at www.ni.com/linux for more informations.
Andrea
