Linking Property Node programmatically to Front Panel objects?
When I right-click on a property node, I see the option to link it to any front panel object.
Can this be done programmatically? I am creating three XY Graphs and I want to know if I can control
the plot color for all three XY Graphs with creating ONLY one property node (plot color) and placing it inside a for loop
and for each iteration of the for loop, linking the property node to different XY Graphs.
(3,040 Views)
Accepted by topic author murchak
what you can do is select the "disconnect from control" option when right clicking on the property node (it will become a generic property node to which you need to pass in an XYGraph control reference), place that property node in a for loop, before the loop, build an array containing references to your 3 XYGaphs (right clic on each XYGraph > create > reference).
Hope this helps
Epictetus
Antoine Chalons
(3,038 Views)
Thank you!!
Can LabVIEW make french fries?
(3,034 Views)
not too sure about french fries but popcorn yes!
Epictetus
Antoine Chalons
(3,032 Views)
And in the wrong hands it is easy to make spaghetti. Smiley Very Happy
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,017 Views)
