07-29-2015 06:48 AM
I am using LabVIEW to acquire data through a LabJack U3-HV. Ultimately I plan on using it with a piezoelectric strain sensor but for now I am just producing square wave using an Arduino Uno to test my program.
The program is fine with signals with fundemental frequencies below 1.6 Hz but anything above that and the results are move like a triangle wave and FFT's of the data don't produce peaks. According to the company website the LabJack has a max sampling rate of 50 Hz so that should not be the limiting factor. I am running a for loop with a wait time of 0 ms but the sampling rate appears to be closer to 35 ms.
Has anyone had this problem before and/or has any ideas about how to solve it?
07-29-2015 06:51 AM
07-29-2015 07:19 AM
In Feedback Function Mode (software timed) the U3 should be able to return 80 to 1000+ samples per second, depending on setting, USB speed, number of channels, and so on. In streaming mode 2500 to 50000 samples per second are possible, depending on resolution. Again thi smay be limited by the USB port or the program configuration.
Lynn
07-29-2015 10:26 AM - edited 07-29-2015 10:26 AM
So switching to stream mode should at least allow me to determine whether or not the LabJack itself is the problem. I have been trying to do this through the LJ UD in LabView but have had no luck. How should I go about changing modes?
Thanks.
07-29-2015 12:52 PM
I am not using Windows so I cannot comment on the LJ UD driver. Two years ago I tried to get thier Mac framework running, but the project was cancelled.
In looking at the stuff I had back then I see Configure Stream U3.vi in the Utilitiy VIs which came with the LJ UD download. I would try starting with that.
Lynn
07-29-2015 09:07 PM
See here for an overview of command-response (software timed) versus stream (hardware timed) mode:
https://labjack.com/support/datasheets/u3/operation
The sub-sections 3.1 and 3.2 have details about the speeds you can achieve with either.
See here for an overview of the UD driver for Windows:
https://labjack.com/support/datasheets/u3/high-level-driver/overview
The LabVIEW examples for the UD driver are here:
https://labjack.com/support/software/examples/ud/labview
To test command-response speeds use the attached "U3 CR Speed Test.vi". To try stream mode, start with "U3 easy Stream Example.vi" from our LabVIEW_LJUD archive.
