04-27-2015 08:21 PM
Wire the ascii code for a comma into the termination character input of the Serial Configure. Decimal 44 or hex 2C.
But it would be more logical to program it to send a linefeed character which is ASCII code decimal 10 or hex 0A. The serial configure already defaults to linefeed as the termination character.
04-27-2015 08:23 PM
Can you help me with an example? I got the idea about Arduino, but I'm new to using LabView, I owe you one for help me, thanks
04-27-2015 08:39 PM
How can I wire the Property Node to just accetp the data that come from write "L" for example?
04-27-2015 08:51 PM - edited 04-27-2015 08:52 PM
I have no idea what you mean by this question.
Attached is a much simpler VI that will work. You just need to program your Arduino to send the LF character at the end of every message it sends out.
04-27-2015 09:05 PM
Really thanks! It works, but just for 10 seconds 😕 after that I have this problem.
04-27-2015 09:19 PM - edited 04-27-2015 09:24 PM
Did you change the code in your Arduino? That message tells me you hadn't received the termination character.
A slightly better version of the VI that takes care of some missing wires and indicators.
04-27-2015 09:23 PM
No my friend, I don't know what I have to change, and What is the mean of this " 100" in write block, this is my Arduino code, What I have to change?
#include "TinyGPS.h"
#include "DHT.h"
TinyGPS gps;
#define GPS_TX_DIGITAL_OUT_PIN 5
#define GPS_RX_DIGITAL_OUT_PIN 6
#define DHTPIN 22 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE);
char in,p,s,t,g;
int temp, hum, solenoide1=50,solenoide2=51,on,leer,cont;
long startMillis;
long secondsToFirstLocation = 0;
#define DEBUG
float latitude = 0.0;
float longitude = 0.0;
float alture=0.0;
void setup() {
#ifdef DEBUG
Serial.begin(9600);
#endif
dht.begin();
Serial3.begin(9600);
// prevent controller pins 5 and 6 from interfering with the comms from GPS
pinMode(GPS_TX_DIGITAL_OUT_PIN, INPUT);
pinMode(GPS_RX_DIGITAL_OUT_PIN, INPUT);
pinMode(hum,OUTPUT);
pinMode(temp,OUTPUT);
pinMode(solenoide1, OUTPUT);
pinMode(solenoide2, OUTPUT);
startMillis = millis();
Serial.println("Starting");
void loop() {
readLocation();
while(Serial.available() )
in =(byte)Serial.read() ;
if(in=='L')
Serial.print(latitude, 6);
Serial.println(" ");
else if(in == 'l'){
Serial.print(longitude, 6);
Serial.println("");
else if(in == 'a'){
Serial.print(alture, 6);
Serial.println("");
else if(in == 'T'){
temp = dht.readTemperature();
Serial.println(temp);
else if(in == 'H'){
hum = dht.readHumidity();
Serial.println(hum);
else if(in == 'p'){
digitalWrite(solenoide1, LOW);
digitalWrite(solenoide2, LOW);
else if(in == 's'){
digitalWrite(solenoide1, HIGH);
else if(in == 't'){
digitalWrite(solenoide2, HIGH);
void readLocation(){
bool newData = false;
unsigned long chars = 0;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial3.available())
int c = Serial3.read();
//Serial.print((char)c); // if you uncomment this you will see the raw data from the GPS
++chars;
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
// we have a location fix so output the lat / long and time to acquire
if(secondsToFirstLocation == 0){
secondsToFirstLocation = (millis() - startMillis) / 1000;
Serial.print("Acquired in:");
Serial.print(secondsToFirstLocation);
Serial.println("s");
unsigned long age;
gps.f_get_position(&latitude, &longitude,&age);
latitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : latitude;
longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : longitude;
alture=gps.f_altitude();
alture == TinyGPS::GPS_INVALID_F_ALTITUDE ? 0.0 : alture;
//Serial.print("Location: ");
/*Serial.print(latitude, 6);
Serial.println("");
Serial.println("");*/
if (chars == 0){
// if you haven't got any chars then likely a wiring issue
Serial.println("Check wiring");
else if(secondsToFirstLocation == 0){
//still working
04-27-2015 09:26 PM
Really thanks for everything man, really thanks!
04-27-2015 09:26 PM
You need to right the linefeed character wherever you send a response.
If you wrote the Arduino code, then YOU should know how to do it. I don't do C code.
In basic it would be something like print#1, chr$(10)
04-27-2015 09:30 PM - edited 04-27-2015 09:33 PM
Thanks man for everything, i'll try it, realyy thanks I never see this code works like this! Thank you so much! 😄 And excuse me that I don't understand some directions, I don't understand English very well, but i'm doing it, Thank you again man.
