Laptop Freezes upon returning from standby when NI-VISA is installed
My Windows XP SP3 laptop was working fine with Labview 2010 installed.  Upon installing NI-VISA 5.0.0 or 5.1.1, the computer generally works fine, but upon returning from Standby, the computer freezes.  (After a few seconds, the screen freezes, and the computer is unresponsive unless I force it to turn off.)
Uninstalling Labview entirely fixes the problem, and reinstalling just Labview does not make it return, but after reinstalling the NI-VISA, the error returns.
Does anyone know how to fix this?
Greg
(2,667 Views)
Hi iggieraver,
Do you leave your laptop running a program which uses VISA calls which then goes to sleep? Is there anything VISA-related running in the background prior to sleeping?
Aldo A
Applications Engineer
(2,637 Views)
I don't believe so. (However, how would I make sure of that?) This error occurs regardless of whether or not I start up Labview. Is there a possibility that something VISA-related could be running and I don't know it?
(2,631 Views)
Hi Greg,
thanks for replying. One quick check you can do is to disable your com ports via the Device Manager. So if anything is using VISA, it won't be able to communicate and hopefully helps us isolate the error. Let me know if your computer continues to freeze after installing VISA, disabling the ports, and coming back from sleep.
Aldo A
(2,574 Views)
I disabled the com port, and still the same.
(2,549 Views)
Thank you for your reply,
Lets do a couple of steps now:
1) Are you on a desktop or laptop?
2) Can you disconnect all USB devices on your computer and re-create the issue?
3) If the issue persists, can you post the log of your computer's Event Viewer (http://support.microsoft.com/kb/308427) when the computer seems to freeze?
Thanks!
Aldo A
(2,543 Views)
