03-15-2006 03:28 AM
03-16-2006 01:34 AM
Hi Jens,
Can I have some more infomations on your question?
What is your application(PDA?) or are you using the .exe file on another computer with lower screen solution ect..
Mybe you can also send me the code you are trying to build, so I can look into it for you.
denmarksupport@ni.com
03-16-2006 09:04 AM
03-16-2006 09:32 AM
03-17-2006 02:15 AM
Hi Soren,
What are the specifications of your PDA(processor and running system)? Dials and inc/dec arrows were defaulted to be 3D for PocketPC but some pda devices has 8-bit(256) color and cannot display the 3D controls.
You can fix this by checking the BITSPIXEL value for the device and accordingly drawing either the 2D or 3D control. Again it depends on your PDA.
Regards
03-17-2006 06:20 AM
03-17-2006 07:37 AM
Sorry for the late responce:
More explanation: I make the EXE program and run the EXE program on the same computer, and the decoration and inr/dec buttons disapear. When I try on another machine the problem is gone.
03-20-2006 01:43 AM
03-20-2006 04:42 AM
03-20-2006 04:49 AM
It seems to be a screen resolution problem..
Can you post or send me you Labview code, then I can look further into the problem.
