03-24-2016 10:38 AM
I have keithley2110 multimeter. I can measured temprature and vlotage of a battery but when i built an exe file from vi and run it on other computer, the measured voltage is shown as an integer value although temprature is ok. Why?
03-24-2016 01:50 PM
Can we see your code?
03-24-2016 03:44 PM
Without seeing your code all I can summarise is you are doing it wrong.
03-26-2016 04:47 AM
Her is my code. In this code ı controll two instruments(Keithley 2110 and 2400). It works on my computer that has Labview with no problems. When i built exe, just measured voltage from 2110 is shown integer values. The others are ok.
Thanks..
03-26-2016 07:07 AM
03-26-2016 07:15 AM - edited 03-26-2016 07:23 AM
Which regional settings. Can you elaborate?
03-26-2016 07:44 AM
03-26-2016 07:45 AM
03-26-2016 08:20 AM
If it proceed from regional setting , why the temprature that is measured from 2110 has no problem?
03-26-2016 11:56 AM
Maybe that function is coded slightly better?
I don't have the Keithley driver available here, so I cannot check this.
But the most reasonable idea (IMHO), when a program only reads "integers", when it read "floats" on a different computer, is to check the regional settings on both computers!
