02-23-2013 03:43 PM
Hi all,
I am new to LabVIEW and interested in using Aardvark USB-I2C tool to talk to an I2C device.
1. Are there any resources [example documentation, sample code, videos ..] you know of that I can refer to?
2. If not, could you provide me a broad overview of the steps I need to implement to successfully read/write to an I2C devce from LabVIEW?
MYT
02-24-2013 10:47 AM
Also, just to add a note, I have downloaded LabVIEW vi examples from Totalphase.
Looking on how to proceed.
1. How do you connect all to create a continous loop that reads a few registers and updates a display?
02-25-2013 10:46 AM
Hi MYT,
Could you be a bit more specific on what you need assistance with? Did you resolve the first issue you posted about? In regards to your second post, if you go to Help > Find Example you will see lots of example on how to display data in the manner you're describing.
02-29-2016 03:14 AM
How can we write data from LabVIEW to aardvark. I am facing problem while writing the data to set values in an experiment related to audio amplifier.
03-01-2016 09:59 AM
Hey MaheshPanigrahi,
I haven't seen much with Aardvark but these examples may point you in the right direction.
These two links should be essentially the same:
