Labview project refuses to remember where it last loaded libraries from
I have a labview project that pulls several source code controled labview libraries into its self.  Everytime I start up the project, the project is saying it can't find VI's within the libraries even though they havn't changed location.  I can manually tell the project where the VI's are and it is happy until I close labview and then re-open the project and I have to go through the whole ordeal again.  Does anyone know why this might be happening?  This is labview 2011 SP1 and we are using accurev for source code control.  I should mention that accurev, by default, puts a read only lock on the libraries, as they shoudnt be modified by the user.  I've done other projects where this hasn't been an issue.
(2,070 Views)
Accepted by topic author MGould
Well, I figured it out.  I had removed a portion of my code and placed it in a seperate library under version control and re added back to the origional project.  I had deleted the origional code that was refactored but hadn't updated the project to reflect the fact that it didn't exist anymore.  After I removed the origional references and made sure it was linking to the new library it wsa happy.
(2,053 Views)
