07-25-2012 07:41 PM
I have a labview project that pulls several source code controled labview libraries into its self. Everytime I start up the project, the project is saying it can't find VI's within the libraries even though they havn't changed location. I can manually tell the project where the VI's are and it is happy until I close labview and then re-open the project and I have to go through the whole ordeal again. Does anyone know why this might be happening? This is labview 2011 SP1 and we are using accurev for source code control. I should mention that accurev, by default, puts a read only lock on the libraries, as they shoudnt be modified by the user. I've done other projects where this hasn't been an issue.
07-26-2012 12:22 PM
Well, I figured it out. I had removed a portion of my code and placed it in a seperate library under version control and re added back to the origional project. I had deleted the origional code that was refactored but hadn't updated the project to reflect the fact that it didn't exist anymore. After I removed the origional references and made sure it was linking to the new library it wsa happy.
