Labview popup message check voltage and hit enter to continue
Can someone please point me to an example of a simple pop up that pauses a program with a message and asks the user to hit Enter to continue?
Basically the power supply in the test is not automated yet
I need to
Pause the program
Tell the operator to set a voltage
Then continue the program
I am guessing this needs to be an event?
Can I trigger on the Error in line?
Any examples would be greatly appreciated
Message 1 of 18
(4,055 Views)
You have to create a subVI with properties (window appearance) set as dialog.
To launch it when it is required we need to know how your main program is build...
Message 3 of 18
(4,042 Views)
Create vi with UI and call it as subVI with "open FP when called"
Message 4 of 18
(4,040 Views)
Edit:
Sorry I just reread your post and noticed that the equipment was not automated.  But if you do automate the attached equipment then my comment below would apply.
My advice is to be careful with pop up messages when you are controlling external equipment.  You can create other issues if you are controlling a piece of equipment and a pop up stops your program waiting for input.
I was controlling a cooling loop on a chamber and everything worked fine.  Then one day while the LN2 solenoid was on for cooling a pop up froze the program waiting for a response.  Luckly LN2 is easy to clean up Smiley Wink and nothing bad happened.
Message 5 of 18
(4,023 Views)
I couldnt find User interface function
Message 6 of 18
(3,997 Views)
sorry dont respond
I have more info
have to go to meeting
Message 7 of 18
(3,994 Views)
I don't have 2015 installed to look at your program.  Right click on the block diagram goto Programming > Dialog & User Interface and look at the Prompt User VI.  Or just search for Prompt User.
Message 8 of 18
(3,987 Views)
try this
edit - i apparently don't understand snippets Smiley Embarassed
Message 9 of 18
(3,978 Views)
Why are we exploring all of these complicated methods to do what was solved a thousand times easier in the first reply?
Throw up the one button dialogue.
Message 10 of 18
(3,966 Views)
